Shows the interval at which the switch automatically clears rule usage statistics.
autoclear | Designates viewing information about auto-clearing policy rule usage statistics. |
interval | Shows the interval in minutes when the switch automatically clears rule usage. Default is 0 (statistics are not automatically cleared). |
By default, the autoclear interval is 0, which means that statistics are not automatically cleared.
If you have configured Syslog and/or trap actions to notify you when a policy rule is used by using the following command: configure policy rule profile_index [{app-signature group group name name} | ether ether | icmp6type icmp6type | icmptype icmptype | ip6dest ip6dest |ipdestsocket ipdestsocket | ipfrag | ipproto ipproto | ipsourcesocket ipsourcesocket | iptos iptos | ipttl ipttl | macdest macdest | macsource macsource | port port | tcpdestportIP tcpdestportIP | tcpsourceportIP tcpsourceportIP | udpdestportIP udpdestportIP | udpsourceportIP udpsourceportIP ] {mask mask } {port-string [ port_string | all]} {storage-type [non-volatile | volatile]} {drop | forward} {syslog syslog} {trap trap} {cos cos } {mirror-destination control_index} {clear-mirror} , this command shows you the interval when these statistics will be cleared.
To set this auto-clear interval, use the following command:
configure policy autoclear {interval interval}
The following example shows the interval for automatically clearing rule usage statistics:
# show policy autoclear interval AutoClear interval is 0 minute(s)
This command was first available in ExtremeXOS 30.2.
